Evertune Bridge?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=49837
Author:  Pmaj7 [ Sat Oct 21, 2017 12:33 am ]
Post subject:  Evertune Bridge?
Anyone ever intonated one of these? I just got one in for a setup and I've never even heard of one. Anything weird/difficult to watch out for? Upcharge?
Author:  Hesh [ Sat Oct 21, 2017 12:39 am ]
Post subject:  Re: Evertune Bridge?
Never did one Pat or I would surely lend a hand. Sorry and I'm not calling you Shirley... ;). Can't sleep here and my humor gets even worse when that happens.... :roll: :D
Author:  Pmaj7 [ Sat Oct 21, 2017 1:15 am ]
Get some sleep Buddy! If this is anything like a Floyd, It's going to Look like I picked the wrong week to quit sniffing glue.
Author:  Colin North [ Sat Oct 21, 2017 4:18 am ]
Have you seen this? https://evertune.com/manuals/quick_start.php
and this https://evertune.com/manuals/pdf/Evertune__UserManual04.pdf
Author:  Hesh [ Sat Oct 21, 2017 4:59 am ]
Colin North wrote:
That's hysterical Colin and I'm LOL here, thanks!!! :D
Author:  Woodie G [ Sat Oct 21, 2017 5:18 am ]
Intonation is straight-forward using a hex wrench and the rearward facing hex head intonation screws - just make sure the instrument is in tune and in the middle of the second tuning zone. The manual covers the process in detail...if the tuning zones are understood, everything else with the Evertune seems to go smoothly. The issues with the bridge are corrosion of the cover and string unit plating and the occasional broken spring. Each string unit is easily replaced, and the cost is reasonable. Evertune technical support is responsive and helpful if the job goes awry.
If you'll have the instrument for more a few hours, it is worth pulling the bridge and separating the string units from the cover/housing to get some insight as to how the device works. We did that when one of the ES-335's came with a broken neck - full disassembly, ultrasonic cleaning, proper re-grease/lubrication, and reassembly.
Author:  Pmaj7 [ Tue Nov 28, 2017 11:22 pm ]
Thanks boys, everything went smooth with the Evertune. I charged $15 extra because had to think for a few minutes. jk but there is a little extra back and forth and back and forth...
